[attachment=13594] Biete hier 4x KV4000 KV 4000 Brushless Motor 35A ESC Gear RC Trex 450 an. Ware ist nagelneu und völlig unbenutzt. 1?Brushless Motor No. Of cells: 3-4x Li-Poly RPM/V: 4000 Max. efficiency current: 8 - 10.5 A (>75%) No load current / 10 V: 0,5 A Current capacity: 40 A/60 s Dimensions:31 x 29 mm Shaft diameter: 3.17mm Weight: 64 g Recomended model weight: 450 class Ele. Heli. Recomended prop without gearbox: 6"-8"? 2?Brushless ESC Size: 57mm x 25mm x 8mm Sustaining Input Voltage: 6-12V BEC Output Current: 5V/3A Continuous Output Current: 35A Max Current: 45A/12s Weight:25g ? Paket beinhaltet: 1X 450 Brushless Motor 1X 450 Brushless ESC 1X 13T Motor Gear Preis: je 26€ + 3,90€ Versand
