Hi, Hab hier noch ein Videosendemodul un 2 passende Empfängermodule. [attachment=13485] Techn. Daten: Transmitter - 5.8G broadband audio and video synchronization FM transmitter - Small size SMD package: 24 × 21 × 5 mm - Transmit Power: 23dBm/200mW - Low power consumption: 12V 150mA - High Output Power: 23dBm (typical) - Built-in high-frequency PLL stability - low harmonic radiation - direct input analog audio and video signals - 8-channel transmitter Receiver - Receive Frequency: 5725-5865MHz; 8 channels - Receiver sensitivity:-90dBm - Frequency Control: Built-in PLL - Dual AV output: output analog audio and video signals directly - Antenna interface: SMA (the pin) - Supply voltage: 6.5-15V - Supply Current: 150mA - 8-channel receiver - Dimension: 30 * 25 * 3mm Preisvorstellung: 45€ incl. Versand
