ComQuest Vertex Hybrid UAV:
[video=youtube_share;vNFmoqj1wVA]http://youtu.be/vNFmoqj1wVA[/video]
A practical VTOL aircraft for UAV enthusiasts
The Vertex Unmanned Aerial Vehicle (UAV) or drone is a hybrid aircraft that combines the hover and Vertical Takeoff or Landing (VTOL) capability of a quadcopter, with the fast and efficient forward flight capabilities of an airplane into one awesome and versatile platform. With the Vertex you can enjoy recreational flight, install your own camera to take unique aerial videos, or install your First Person View (FPV) system to get new aerial perspectives.
Versatile Aerial Filming and FPV Platform
The Vertex was designed with aerial filming and first person view (FPV) flight in mind. The Vertex comes with custom adapters to attach your own GoPro camera, or a Tarot T2D gimbal with GoPro 3 camera. Adapters for other cameras or gimbals can be 3D printed. All Vertex configurations can lift the camera, gimbal and FPV system at the same time.
How does the Vertex Hybrid work?
The Vertex employs a unique patent pending design which combines four independently tilting propulsion units for maximum control and stability with two tandem wings for forward flight efficiency. The custom control algorithms and reliable flight transition mechanism enable stable flight at any transition angle between hover and forward flight. This gives the pilot the flexibility of vertical takeoffs and landings from just about anywhere, precise maneuvering in small spaces, or fast forward flight in large areas. Activate the auto-level flight mode for ease of flight, or use the stabilization flight mode to have full control of the aircraft.
