Direkt vom Entwickler SSassen ausm
RCGroups Forum
For properly installing the EzOSD and its integrated GPS receiver a few things are important:
1) Mount the EzOSD so it has clear view of the sky, with the GPS antenna facing upwards. Make sure no cables, carbon fiber, metal or other materials are blocking it, or are close by.
2) Make sure the EzOSD is clear of wires that carry large currents (the ESC wires, or the wires to the motor), mount it as far away from these as possible.
3) Never mount an audio/video Tx close (several centimeters/inches) to the EzOSD.
4) Make sure that the EzOSD never sits below an audio/video Tx as then the audio/video Tx will be in 'view' of the integrated GPS.
5) The GPS is sensitive to multipathing (Google if you're not sure what that means) and only works well in an environment with little to no reflections. Don't expect to get a lock inside a house, in an alley or in an area surrounded by large houses/flats/high rises/etc. and open field works best.
6) If the EzOSD doesn't get a full lock in 5 minutes, power it down (remove battery), wait 2 to 3 minutes and power back up.
Allgemein BEC und Videosender (2.4 auf jeden Fall und 5.8 dann bestimmt auch) stören die Satellitensuche.
Bei mir dauerts nah am Regler minutenlang,ohne BEC in der Nähe hab ich in 1-2 min alle Satelliten....
Zum Ez Tiny Telemetry bzw Akkuanzeige wird doch
hier alles gesagt.
Gruß Kampfpilot
