Was neues von Flywoo. Schön leicht aber mit aktuell 599$ leider auch recht teuer.
Flywoo Action Camera GP11 is an ultimate and ultra-light design based on the Gopro Hero 11, specially made for FPV. We removed the traditional GoPro case and kept only what was necessary for the FPV , and designed a new case and BEC.
Specifications:
Specifications:
- Model: Flywoo Action Camera GP11
- Brand name: FLYWOO
- Video Ratios:16:9/4:3/8:7
- Video Stabilization:HyperSmooth 5.0
- Video: 5K@60fps/4K@120fps/2.7K@240fps
- 120Mbps Bit Rate 5.3K, 4K
- Video format:MP4,
- Video code: H.264/AVC,H.265AEVC
- Input voltage: 2S-6S,Suit for 2S-6S Batteries
- Output: 5V@2A
- Connector: SH1.0-3P Connector
- Protection: UV proction lens
- Filter: CPL/ND4/ND8/ND16/ND32/ND64(optional)
- Size: 67mm*48mm*20mm
- Weight: 44.6g
- You can choose to order a touch screen (more convenient to set parameters) Note: If you order a touch screen version, we will match everything. Every touchscreen is unique. Once damaged, you cannot order a replacement.
- Compared with the traditional Naked gopro, we have added an aluminum sheet to reinforce and make it more durable.
- Rear small fan, better heat dissipation, can continuously shoot 4K 120FPS (Gopro 10 bone, naked gopro can't, it will shut down in 5 minutes at most)
- Compared with Gopro10 bones, GP9/10/11 is lighter, only 44g, more suitable for FPV players
- Built-in front screen, optional rear touch screen
- The gravity of GP9/10/11 is in the middle, which is more conducive to FPV flying and shooting.
