Bei HorusRC finden sich angekündigte Neuheiten:
1. FrSky XSRF4O
Description:
- Dimension: 36x36x6mm (L x W x H) with 30.5mm mounting holes
- Integrate with XSR receiver
- 1~16 channels from Sbus output
- 1~6 channels from PWM outputs
- S.Port enabled, support telemetry data transmission and more sensors
- OSD Configuration has been included in Betaflight GUI.
- Built-in SD slot
- Built-in F4 STM32F405 CPU
- Built-in 6-axis sensor MPU6000 (Accelerometer/Gyro)
- Built-in BARO BMP280
2. FrSky XSRF3PO
Description:
- Dimension:60x36x6mm (L x W x H) with 30.5mm mounting holes
- 1~8 channels from PWM outputs
- Built-in SD slot
- Built-in F3 STM32F303 CPU
- Built-in 6-axis sensor MPU6050 (Accelerometer/Gyro)
- Built-in on-board PDB up to 6S integrate with current sensor
3. FrSky XSRF4PO
Description:
- Weight: 14g
- Built-in SD slot
4. FrSky XSRF3O
Description:
- Weight: 6g
- Built-in SD slot
1. FrSky XSRF4O
Description:
- Built-in SD slot
2. FrSky XSRF3PO
Description:
- Built-in SD slot
3. FrSky XSRF4PO
Description:
- Weight: 14g
- Built-in SD slot
4. FrSky XSRF3O
Description:
- Weight: 6g
- Built-in SD slot
