Specification:
Dimension: 46.47×26.78×14.12 mm (L×W×H)
Weight: 14g
Number of Channels: 8/16CH (1-8ch from conventional channel outputs, 1-16ch from SBUS output)
With RSSI PWM output on board: PWM voltage output(0-3.3V), 100Hz, 1500±500us
Operating Current: 120mA@5V
Operating Voltage Range: 4.0-10V
Operating Range: full range
Gyroscope Measurement Range: ±2000dps
Accelerometer Measurement Range: ±4g
Firmware Upgradeable
Compatibility: FrSky Taranis X9D Plus/X9E/X7/Horus X12S/XJT in D16 mode
(PS: S8R-EU only works with FrSky Taranis X9D Plus/X9E/X7/Horus X12S/XJT in D16-EU mode)
Features:
Built-in 3-axis gyroscope and 3-axis accelerometer sensor module
Built-in RSSI PWM output(0-3.3V)
Built-in battery voltage detection
Smart Port enabled
SBUS Port enabled
Function:
The S8R supports stabilization, automatic level, hover and Knife-edge flight modes for conventional modes, stabilization and automatic level for Delta Wing (flying wing) and V-tail models. These model types can be enabled via the S8R.Config or S8R.lua. The S8R can be used as a standard 8 channel X series receiver if it is required.
More Details Link: http://www.frsky-rc.com/product/pro.php?pro_id=177
Retail Price (Tax Excluded): US$ 34
