VERKAUFT Runcam 2
heli35
[TABLE="class: table parameter-table, width: 100%"]
[TR]
[TD]Angle of Field[/TD]
[TD]FOV 120°[/TD]
[/TR]
[TR]
[TD]Sensor Resolution[/TD]
[TD]4 megapixels[/TD]
[/TR]
[TR]
[TD]Video Resolution[/TD]
[TD]1440p@30fps / 1080p@60fps / 720p@120fps[/TD]
[/TR]
[TR]
[TD]Video Files[/TD]
[TD]MOV[/TD]
[/TR]
[TR]
[TD]TV Output[/TD]
[TD]NTSC / PAL[/TD]
[/TR]
[TR]
[TD]Interface[/TD]
[TD]Micro USB[/TD]
[/TR]
[TR]
[TD]Max Micro SD Card Supported[/TD]
[TD]64G(need class 6 or above)[/TD]
[/TR]
[TR]
[TD]Image Flip(Manual/Auto)[/TD]
[TD]180[SUP]°[/SUP] Rotation[/TD]
[/TR]
[TR]
[TD]Dimension[/TD]
[TD]66mm(L) * 38mm(W) * 21mm(H)[/TD]
[/TR]
[TR]
[TD]Battery Capacity[/TD]
[TD]850 mAh[/TD]
[/TR]
[TR]
[TD]USB Power Input[/TD]
[TD]DC 5V-17V[/TD]
[/TR]
[TR]
[TD]Working Current[/TD]
[TD]< 600 mA[/TD]
[/TR]
[TR="class: border-bottom"]
[TD]Weight[/TD]
[TD]49g(with battery) / 35g(without battery)[/TD]
[/TR]
[/TABLE]
Neuwertig VB 70€ +Versand
Ie0n
Wäre dran interessiert, kann aber erst in 4 Tagen zahlen. Wenn jemand anderes die Runcam haben will hat dieser Vorrang.
