war erst einmal auf den Flugplatz; wir haben morgen Flugtag.
Da ich mich im Programmieren nicht auskenne, wie komme ich in den Debugger?
Wolfgang
Habe ihn gefunden!
Hier die Einträge:
f_opendir(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/SYSTEM) = OK
f_closedir(0103F99C)
f_close(00000000) (FIL:77BB3BF0)
f_opendir(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/Champion) = error 2 (No such file or directory)
findTrueFileName(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/BMP/Solius.bmp)
found: Solius.bmp
f_open(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/BMP/Solius.bmp) = error 13 (Permission denied)
playFile("/SOUNDS/de/Champion/name.wav", flags=0, id=0)
findTrueFileName(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/Champion/name.wav)
not found
f_open(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/Champion/name.wav) = INVALID_NAME
playFile("/SOUNDS/de/siglow.wav", flags=0, id=15)
playFile("/SOUNDS/de/SYSTEM/0000.wav", flags=0, id=20)
playFile("/SOUNDS/de/SYSTEM/0111.wav", flags=0, id=20)
playFile("/SOUNDS/de/Champion.wav", flags=0, id=25)
findTrueFileName(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/siglow.wav)
found in map: C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/siglow.wav
f_open(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/siglow.wav) = error 13 (Permission denied)
findTrueFileName(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/SYSTEM/0000.wav)
found: 0000.wav
f_open(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/SYSTEM/0000.wav) = error 13 (Permission denied)
findTrueFileName(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/SYSTEM/0111.wav)
found: 0111.wav
f_open(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/SYSTEM/0111.wav) = error 13 (Permission denied)
findTrueFileName(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/Champion.wav)
found: Champion.wav
f_open(C:\Program Files (x86)\OpenTX\Companion 2.0\SD Card/SOUNDS/de/Champion.wav) = error 13 (Permission denied)
eeprom write model
"error 13 (Permission denied)" -warum keine Berchtigung? Desshalb wohl auch keine Ausgabe!
Alle wav-Dateien sind vorhanden.
Wolfgang
