hy
und hier mal die Umrechnungen
Anmerkungen sind von mir:
PW = Pulsbreite
DX8 und Taranis
To followup on my post about DX8 vs taranis travel limits. I connected a logic analyzer
to the throttle output of a spektrum ar6115e receiver.
DX8
100% Servo Travel for Throttle
0% PW = 1.11 ms
100% PW = 1.91 ms
Center PW = (0% + 100%)/2 = 1.51ms
Total +/-PW change from center = 40ms Anmerkung: das muss +-400us heißen!!
150% Servo Travel For Throttle
0% PW = 0.91 ms
100% PW = 2.11 ms
Total +/-PW change from center = 60ms Anmerkung: das muss +-600us heißen!!
Taranis with OrangeRx Module
-100,+100 Limits for Throttle
-100 PW = 0.99 ms
+100 PW = 2.02 ms
Center PW = (-100 + +100)/2 = 1.51ms
Total +/-PW change from center = 52ms Anmerkung: das muss +-520us heißen!!
The DX8 100% Servo Travel to Taranis Min/Max Limit conversion = 40/52 = 0.77.
I changed the Taranis Limits to verify the math (-77,+77) and the results were spot on.
Since the taranis at -/+100 Min/Max limits didnt quite match the spektrum range at 150%, I enabled the extended limits on the taranis and set the Min/Max to -125/+125
-->Von mir gelöscht!
The conversion factor here is a little off from the previous = 125/150 = 0.83
So just multiply the dx8 servo travel by 0.8 to get the equivalent taranis -/+ limits and
call it a day and you can use all your other dx8 settings as is on your taranis
Anmerkungen von mir:
Da ist auch etwas Murks drinnen, den habe ich gelöscht!
Dafür habe ich mal zusammengefasst
Da hat er sich offensichtlich ein paar mal verrechnet oder am Logicanalyser falsch abgelesen
0,40ms = 400us
0,60ms = 600us
0,52ms = 520us
0,70ms = 700us
Taranis macht exakt:
Mitte 1500us = 0%
+- 512us = +-100% = +2012us - 988us
+- 640us = +-125% = +2140us - 860us
+- 768us = +-150% = +2268us - 732us
DX8 macht exakt:
Mitte 1500us = 0%
+- 400us = +-100% = +1900us - 1100us
+- 600us = +-150% = +2100us - 900us
Exakte Umrechnung der Pulsbreiten DX8 auf Taranis
DX8 100%, Taranis 100% : 400us / 512us = 0,78125
DX8 150%, Taranis 125% : 600us / 640us = 0,93757
DX8 150%, Taranis 150% : 600us / 768us = 0,78125
Die Umrechungen müssen sich immer auf die
echten Pulsweitensignale beziehen, nie auf %-Werte
deshalb sind obige 0,83 falsch!
Helle
