Zu verkaufen neuwertigen Fy91-q mit GPS.
Funktioniert einwadfrei, mit neuem Softwareupdate.
Sehr viele Parameter Einstellungen möglich.
Läuft mit 4, 6, 8 Rotoren und verschiedenen Copter Anordnungen.
Sehr fein zum fliegen ideal für fpv oder fotografieren.
Neuwertig, gekauft im August 2011, also noch mit Garantie.
Verkaufspreis: SFr. 250.- + Versand
Versand ins Ausland auch möglich, Bezahlung dann per PayPal
Feiyu Tech DreamCatcher Navigation Edition Multirotor Flight Stabilization & Autopilot System
FY-91Q DreamCather Navigaion Edition comes with FY-91Q, Compass & GPS, works with Quadcopters, Y4, Y6 Tri-axial rotory aircrafts and Hexacopters. This is capable for autopilot, auto return to home and auto hover.
FY91Q MULTI ROTOR SYSTEM
Basics on how the system works:
• Inertial Stabilizer: The FY91Q utilizes an attitude flight stabilization system
(AFSS) which is inertial sensing based. The system also incorporates an autonomous
flight control system.
• The FY91Q AFSS integrates a three-axis gyroscope combined with tri-axial
accelerometers to sense and create a drift-free 3 dimensional stabilization system.
• The FY91Q also utilizes GPS and barometric pressure sensing to obtain accurate
aircraft positioning and altitude.
• By combining sensor data from the gyros and accelerometers, together with altitude
and GPS positioning, an accurate inertial navigation and autopilot system is formed.
Fixed positioned and altitude hover and return to home is just a switch away.
• This product is still under intense Research and Development. FeiYu Tech has
enabled firmware upgrading via a USB-TTL Connector. As new algorithms are
developed for the autopilot system, you can download the upgraded firmware from
FY website.
Barometer and GPS & COMPASS module
v FY-91Q control module incorporates an accurate barometric pressure sensor. At
start up, the take-off air pressure is measured, providing the autopilot with an
accurate relative height data.
v The GPS & COMPASS module provided with the FY91Q Navigation Edition
consist of a three-axis magnetic sensor and high sensitivity GPS receiver. This
module enables the autopilot to sense the flight course and exact location of the
aircraft.
v Note that if the FY91Q is not connected GPS & COMPASS module, it will function
as purely as a flight stabilizer for multi rotor aircraft. The autonomous flight
system cannot be engaged.
v For the autopilot to function, the GPS Receiver must detect at least 5 satellites.
FY91Q MULTI ROTOR SYSTEM Basics on how the system works:
Inertial Stabilizer: The FY91Q utilizes an attitude flight stabilization system(AFSS) which is inertial sensing based. The system also incorporates an autonomousflight control system.
The FY91Q AFSS integrates a three-axis gyroscope combined with tri-axialaccelerometers to sense and create a drift-free 3 dimensional stabilization system.
The FY91Q also utilizes GPS and barometric pressure sensing to obtain accurateaircraft positioning and altitude.
By combining sensor data from the gyros and accelerometers, together with altitudeand GPS positioning, an accurate inertial navigation and autopilot system is formed.Fixed positioned and altitude hover and return to home is just a switch away.
This product is still under intense Research and Development. FeiYu Tech hasenabled firmware upgrading via a USB-TTL Connector. As new algorithms aredeveloped for the autopilot system, you can download the upgraded firmware fromFY website.
FY-91Q control module incorporates an accurate barometric pressure sensor. Atstart up, the take-off air pressure is measured, providing the autopilot with anaccurate relative height data.
The GPS & COMPASS module provided with the FY91Q Navigation Editionconsist of a three-axis magnetic sensor and high sensitivity GPS receiver. Thismodule enables the autopilot to sense the flight course and exact location of theaircraft.
Note that if the FY91Q is not connected GPS & COMPASS module, it will functionas purely as a flight stabilizer for multi rotor aircraft. The autonomous flightsystem cannot be engaged.
Autopilot Function
The current FY91Q firmware supports two autopilot functions; fixed altitude Auto Hover and automated Return to Home. To enable autonomous flight, the GPS & Compass module must be connected to the FY91Q
Auto Hover
3 dimensional GPS positioning is used to automatically maintain aircraft hover position and altitude.
Accuracy of hover position (range) depends on wind conditions and speed.
Automated Return to Home
By utilizing GPS positioning, the autopilot will return the aircraft to the starting point upon activation of the RTH Mode.
Upon reaching the starting point (home) the autopilot will activate Hover Hold, maintaining position and altitude while waiting for your further instructions.
To establish the Home point, a minimum of 5 GPS satellites must be detected
ON SCREEN DISPLAY and DATA RADIO
The FY91Q supports OSD data output via the UART interface.
By connecting this interface to the AP117 OSD, telemetric data such as GPS, flight navigation, AHI, and autopilot modes can be displayed on your downlink video.
The UART Interface can also be connected to the FY-606 digital data radio system, which establishes a bi-direction radio communication between the FY91Q and your portable computer.
By uploading our Ground Control Software (GCS) (free from our website), you can monitor your flight on the GCS map, display on-board telemetry data and control the aircraft flight path via the click of your mouse.
SYSTEM SPECIFICATIONS
FY-91Q Module
Operating voltage 4.0~6.0 Volt
Current consumption 50mA (5V input)
Dimensions 55 x 33 x 20 mm
Weight (not including wires) 20g
Operating Temperature -25°C~ +70°C
The maximum allowable rotation rate 3 rotations per minute
GPS & COMPASS INTERFACE MODULE
Current consumption 60mA (5V input)
Weight (not including wire) 20g
Temperature range -25°C~ +70°C
APPLICABLE AIRCRAFT MODELS The FY91Q can be installed and flown it the following multi-rotor aircraft:
Quadcopters;
Tri-axial rotory aircraft with 6 motors (Y6)
Tri-axial rotory aircraft with 4 motors (Y4)
Six-axial multi-rotor aircraft (Hexacopters)
In the box of FY91Q Navigation Edition Package
1 x FY-91Q control module
1 x FY-91Q RC receiver connection cable pack
1 x GPS & COMPASS Interface module
1 x FY GPS Receiver
1 x Double-sided adhesive Damper pad
2 x Self-adhesive Velcro sponge
1 x GPS connecting wires
1 x Jumper for gyro resetting
FY website.
aircraft.
Autopilot Function
Auto Hover
FY-91Q Module
Quadcopters;
1 x FY GPS Receiver
