#NOTE: 23.03.2017 15:44:07 Frame :
ACCEL_Z_D,0
ACCEL_Z_FILT,20
ACCEL_Z_I,1
ACCEL_Z_IMAX,800
ACCEL_Z_P,0.5
ACRO_BAL_PITCH,1
ACRO_BAL_ROLL,1
ACRO_RP_EXPO,0.3
ACRO_RP_P,4.5
ACRO_THR_MID,0
ACRO_TRAINER,2
ACRO_Y_EXPO,0
ACRO_YAW_P,4.5
ADSB_ENABLE,0
AHRS_COMP_BETA,0.1
AHRS_EKF_TYPE,2
AHRS_GPS_GAIN,1
AHRS_GPS_MINSATS,6
AHRS_GPS_USE,1
AHRS_ORIENTATION,0
AHRS_RP_P,0.2
AHRS_TRIM_X,-0.009614472
AHRS_TRIM_Y,0.01051272
AHRS_TRIM_Z,0
AHRS_WIND_MAX,0
AHRS_YAW_P,0.2
ANGLE_MAX,4500
ARMING_CHECK,1
ATC_ACCEL_P_MAX,110000
ATC_ACCEL_R_MAX,110000
ATC_ACCEL_Y_MAX,27000
ATC_ANG_LIM_TC,1
ATC_ANG_PIT_P,4.5
ATC_ANG_RLL_P,4.5
ATC_ANG_YAW_P,4.5
ATC_ANGLE_BOOST,1
ATC_RAT_PIT_D,0.0036
ATC_RAT_PIT_FILT,20
ATC_RAT_PIT_I,0.09
ATC_RAT_PIT_IMAX,0.444
ATC_RAT_PIT_P,0.135
ATC_RAT_RLL_D,0.0036
ATC_RAT_RLL_FILT,20
ATC_RAT_RLL_I,0.09
ATC_RAT_RLL_IMAX,0.444
ATC_RAT_RLL_P,0.135
ATC_RAT_YAW_D,0
ATC_RAT_YAW_FILT,5
ATC_RAT_YAW_I,0.018
ATC_RAT_YAW_IMAX,0.222
ATC_RAT_YAW_P,0.18
ATC_RATE_FF_ENAB,1
ATC_SLEW_YAW,6000
ATC_THR_MIX_MAX,0.5
ATC_THR_MIX_MIN,0.1
AUTOTUNE_AGGR,0.1
AUTOTUNE_AXES,7
AUTOTUNE_MIN_D,0.001
AVD_ENABLE,0
AVOID_ENABLE,3
BATT_AMP_OFFSET,0
BATT_AMP_PERVOLT,17
BATT_CAPACITY,3300
BATT_CURR_PIN,3
BATT_MONITOR,0
BATT_VOLT_MULT,10.1
BATT_VOLT_PIN,2
BATT2_AMP_OFFSET,0
BATT2_AMP_PERVOL,17
BATT2_CAPACITY,3300
BATT2_CURR_PIN,3
BATT2_MONITOR,0
BATT2_VOLT_MULT,10.1
BATT2_VOLT_PIN,2
BRD_CAN_ENABLE,0
BRD_IMU_TARGTEMP,-1
BRD_PWM_COUNT,4
BRD_SAFETY_MASK,16320
BRD_SAFETYENABLE,1
BRD_SBUS_OUT,0
BRD_SER1_RTSCTS,2
BRD_SER2_RTSCTS,2
BRD_SERIAL_NUM,0
BRD_TYPE,2
BTN_ENABLE,0
CAM_DURATION,10
CAM_FEEDBACK_PIN,-1
CAM_FEEDBACK_POL,1
CAM_MAX_ROLL,0
CAM_MIN_INTERVAL,0
CAM_RELAY_ON,1
CAM_SERVO_OFF,1100
CAM_SERVO_ON,1300
CAM_TRIGG_DIST,0
CAM_TRIGG_TYPE,0
CH10_OPT,0
CH11_OPT,0
CH12_OPT,0
CH7_OPT,0
CH8_OPT,0
CH9_OPT,0
CHUTE_ENABLED,0
CIRCLE_RADIUS,1000
CIRCLE_RATE,20
CLI_ENABLED,0
COMPASS_AUTODEC,1
COMPASS_CAL_FIT,8
COMPASS_DEC,0
COMPASS_DEV_ID,73225
COMPASS_DEV_ID2,131594
COMPASS_DEV_ID3,0
COMPASS_DIA_X,1.097452
COMPASS_DIA_Y,0.9663869
COMPASS_DIA_Z,1.029163
COMPASS_DIA2_X,1.061104
COMPASS_DIA2_Y,1.178377
COMPASS_DIA2_Z,1.020516
COMPASS_DIA3_X,0
COMPASS_DIA3_Y,0
COMPASS_DIA3_Z,0
COMPASS_EXTERN2,0
COMPASS_EXTERN3,0
COMPASS_EXTERNAL,1
COMPASS_LEARN,0
COMPASS_MOT_X,0
COMPASS_MOT_Y,0
COMPASS_MOT_Z,0
COMPASS_MOT2_X,0
COMPASS_MOT2_Y,0
COMPASS_MOT2_Z,0
COMPASS_MOT3_X,0
COMPASS_MOT3_Y,0
COMPASS_MOT3_Z,0
COMPASS_MOTCT,0
COMPASS_ODI_X,-0.02576143
COMPASS_ODI_Y,-0.02726072
COMPASS_ODI_Z,0.01640477
COMPASS_ODI2_X,-0.02537178
COMPASS_ODI2_Y,0.0007989372
COMPASS_ODI2_Z,0.02323159
COMPASS_ODI3_X,0
COMPASS_ODI3_Y,0
COMPASS_ODI3_Z,0
COMPASS_OFS_X,0
COMPASS_OFS_Y,240
COMPASS_OFS_Z,-45
COMPASS_OFS2_X,1
COMPASS_OFS2_Y,224
COMPASS_OFS2_Z,-212
COMPASS_OFS3_X,0
COMPASS_OFS3_Y,0
COMPASS_OFS3_Z,0
COMPASS_ORIENT,0
COMPASS_ORIENT2,0
COMPASS_ORIENT3,0
COMPASS_PRIMARY,0
COMPASS_USE,1
COMPASS_USE2,1
COMPASS_USE3,1
DEV_OPTIONS,0
DISARM_DELAY,10
EK2_ABIAS_P_NSE,0.005
EK2_ACC_P_NSE,0.6
EK2_ALT_M_NSE,3
EK2_ALT_SOURCE,0
EK2_CHECK_SCALE,100
EK2_EAS_I_GATE,400
EK2_EAS_M_NSE,1.4
EK2_ENABLE,1
EK2_FLOW_DELAY,10
EK2_FLOW_I_GATE,300
EK2_FLOW_M_NSE,0.25
EK2_GBIAS_P_NSE,0.0001
EK2_GLITCH_RAD,25
EK2_GPS_CHECK,31
EK2_GPS_DELAY,220
EK2_GPS_TYPE,0
EK2_GSCL_P_NSE,0.0005
EK2_GYRO_P_NSE,0.03
EK2_HGT_DELAY,60
EK2_HGT_I_GATE,500
EK2_IMU_MASK,3
EK2_LOG_MASK,1
EK2_MAG_CAL,3
EK2_MAG_I_GATE,300
EK2_MAG_M_NSE,0.05
EK2_MAGB_P_NSE,0.0001
EK2_MAGE_P_NSE,0.001
EK2_MAX_FLOW,2.5
EK2_NOAID_M_NSE,10
EK2_POS_I_GATE,500
EK2_POSNE_M_NSE,1
EK2_RNG_I_GATE,500
EK2_RNG_M_NSE,0.5
EK2_RNG_USE_HGT,-1
EK2_TAU_OUTPUT,25
EK2_TERR_GRAD,0.1
EK2_VEL_I_GATE,500
EK2_VELD_M_NSE,0.7
EK2_VELNE_M_NSE,0.5
EK2_WIND_P_NSE,0.1
EK2_WIND_PSCALE,0.5
EK2_YAW_I_GATE,300
EK2_YAW_M_NSE,0.5
EKF_ENABLE,0
EPM_ENABLE,0
ESC_CALIBRATION,0
FENCE_ACTION,1
FENCE_ALT_MAX,100
FENCE_ENABLE,0
FENCE_MARGIN,2
FENCE_RADIUS,300
FENCE_TOTAL,0
FENCE_TYPE,7
FLOW_ENABLE,0
FLOW_FXSCALER,0
FLOW_FYSCALER,0
FLOW_ORIENT_YAW,0
FLTMODE1,0
FLTMODE2,2
FLTMODE3,5
FLTMODE4,11
FLTMODE5,7
FLTMODE6,6
FRAME,1
FS_BATT_ENABLE,0
FS_BATT_MAH,0
FS_BATT_VOLTAGE,10.5
FS_CRASH_CHECK,1
FS_EKF_ACTION,1
FS_EKF_THRESH,0.8
FS_GCS_ENABLE,1
FS_THR_ENABLE,1
FS_THR_VALUE,1000
GCS_PID_MASK,0
GND_ABS_PRESS,99714.14
GND_ALT_OFFSET,0
GND_EFFECT_COMP,0
GND_PRIMARY,0
GND_TEMP,23.35271
GPS_AUTO_CONFIG,1
GPS_AUTO_SWITCH,1
GPS_GNSS_MODE,0
GPS_GNSS_MODE2,0
GPS_HDOP_GOOD,140
GPS_INJECT_TO,127
GPS_MIN_DGPS,100
GPS_MIN_ELEV,-100
GPS_NAVFILTER,8
GPS_RATE_MS,200
GPS_RATE_MS2,200
GPS_RAW_DATA,0
GPS_SAVE_CFG,0
GPS_SBAS_MODE,2
GPS_SBP_LOGMASK,-256
GPS_TYPE,1
GPS_TYPE2,0
INS_ACC_BODYFIX,2
INS_ACC2OFFS_X,0.584763
INS_ACC2OFFS_Y,0.3240349
INS_ACC2OFFS_Z,0.5869678
INS_ACC2SCAL_X,0.9991179
INS_ACC2SCAL_Y,1.011814
INS_ACC2SCAL_Z,1.03763
INS_ACC3OFFS_X,0
INS_ACC3OFFS_Y,0
INS_ACC3OFFS_Z,0
INS_ACC3SCAL_X,0
INS_ACC3SCAL_Y,0
INS_ACC3SCAL_Z,0
INS_ACCEL_FILTER,20
INS_ACCOFFS_X,0.02400952
INS_ACCOFFS_Y,-0.2051992
INS_ACCOFFS_Z,-0.1193513
INS_ACCSCAL_X,0.9948688
INS_ACCSCAL_Y,0.995176
INS_ACCSCAL_Z,0.984135
INS_GYR_CAL,1
INS_GYR2OFFS_X,0.009582972
INS_GYR2OFFS_Y,0.01367079
INS_GYR2OFFS_Z,4.845049E-05
INS_GYR3OFFS_X,0
INS_GYR3OFFS_Y,0
INS_GYR3OFFS_Z,0
INS_GYRO_FILTER,20
INS_GYROFFS_X,0.004751479
INS_GYROFFS_Y,0.00707479
INS_GYROFFS_Z,-0.008811528
INS_PRODUCT_ID,5
INS_STILL_THRESH,2.5
INS_TRIM_OPTION,1
INS_USE,1
INS_USE2,1
INS_USE3,0
LAND_REPOSITION,1
LAND_SPEED,50
LAND_SPEED_HIGH,0
LGR_SERVO_DEPLOY,1750
LGR_SERVO_RTRACT,1250
LOG_BACKEND_TYPE,1
LOG_BITMASK,176126
LOG_DISARMED,0
LOG_FILE_BUFSIZE,16
LOG_REPLAY,0
MAG_ENABLE,1
MIS_RESTART,0
MIS_TOTAL,0
MNT_ANGMAX_PAN,4500
MNT_ANGMAX_ROL,4500
MNT_ANGMAX_TIL,4500
MNT_ANGMIN_PAN,-4500
MNT_ANGMIN_ROL,-4500
MNT_ANGMIN_TIL,-4500
MNT_DEFLT_MODE,3
MNT_JSTICK_SPD,0
MNT_LEAD_PTCH,0
MNT_LEAD_RLL,0
MNT_NEUTRAL_X,0
MNT_NEUTRAL_Y,0
MNT_NEUTRAL_Z,0
MNT_RC_IN_PAN,0
MNT_RC_IN_ROLL,0
MNT_RC_IN_TILT,0
MNT_RETRACT_X,0
MNT_RETRACT_Y,0
MNT_RETRACT_Z,0
MNT_STAB_PAN,0
MNT_STAB_ROLL,0
MNT_STAB_TILT,0
MNT_TYPE,0
MOT_BAT_CURR_MAX,0
MOT_BAT_CURR_TC,5
MOT_BAT_VOLT_MAX,0
MOT_BAT_VOLT_MIN,0
MOT_HOVER_LEARN,2
MOT_PWM_MAX,0
MOT_PWM_MIN,0
MOT_PWM_TYPE,0
MOT_SPIN_ARM,0.1
MOT_SPIN_MAX,0.95
MOT_SPIN_MIN,0.15
MOT_THST_EXPO,0.65
MOT_THST_HOVER,0.5
MOT_YAW_HEADROOM,200
NTF_BUZZ_ENABLE,1
NTF_LED_BRIGHT,3
NTF_LED_OVERRIDE,0
PHLD_BRAKE_ANGLE,3000
PHLD_BRAKE_RATE,8
PILOT_ACCEL_Z,250
PILOT_THR_BHV,0
PILOT_THR_FILT,0
PILOT_TKOFF_ALT,0
PILOT_TKOFF_DZ,100
PILOT_VELZ_MAX,250
PLND_ENABLED,0
POS_XY_P,1
POS_Z_P,1
PRX_ORIENT,0
PRX_TYPE,0
PRX_YAW_CORR,22
PSC_ACC_XY_FILT,2
RALLY_INCL_HOME,1
RALLY_LIMIT_KM,0.3
RALLY_TOTAL,0
RC_FEEL_RP,50
RC_SPEED,490
RC1_DZ,30
RC1_MAX,2006
RC1_MIN,982
RC1_REV,1
RC1_TRIM,1490
RC10_DZ,0
RC10_FUNCTION,0
RC10_MAX,1998
RC10_MIN,982
RC10_REV,1
RC10_TRIM,982
RC11_DZ,0
RC11_FUNCTION,0
RC11_MAX,1750
RC11_MIN,1238
RC11_REV,1
RC11_TRIM,1494
RC12_DZ,0
RC12_FUNCTION,0
RC12_MAX,2006
RC12_MIN,982
RC12_REV,1
RC12_TRIM,1496
RC13_DZ,0
RC13_FUNCTION,0
RC13_MAX,2006
RC13_MIN,982
RC13_REV,1
RC13_TRIM,1494
RC14_DZ,0
RC14_FUNCTION,0
RC14_MAX,2006
RC14_MIN,982
RC14_REV,1
RC14_TRIM,982
RC2_DZ,30
RC2_MAX,2006
RC2_MIN,982
RC2_REV,1
RC2_TRIM,1496
RC3_DZ,30
RC3_MAX,2006
RC3_MIN,1032
RC3_REV,1
RC3_TRIM,1032
RC4_DZ,40
RC4_MAX,2006
RC4_MIN,982
RC4_REV,1
RC4_TRIM,1494
RC5_DZ,0
RC5_FUNCTION,0
RC5_MAX,2006
RC5_MIN,982
RC5_REV,1
RC5_TRIM,982
RC6_DZ,0
RC6_FUNCTION,0
RC6_MAX,1900
RC6_MIN,1100
RC6_REV,1
RC6_TRIM,1494
RC7_DZ,0
RC7_FUNCTION,0
RC7_MAX,2006
RC7_MIN,1494
RC7_REV,1
RC7_TRIM,1494
RC8_DZ,0
RC8_FUNCTION,0
RC8_MAX,1904
RC8_MIN,982
RC8_REV,1
RC8_TRIM,982
RC9_DZ,0
RC9_FUNCTION,0
RC9_MAX,1968
RC9_MIN,982
RC9_REV,1
RC9_TRIM,1968
RCMAP_PITCH,2
RCMAP_ROLL,1
RCMAP_THROTTLE,3
RCMAP_YAW,4
RELAY_DEFAULT,0
RELAY_PIN,54
RELAY_PIN2,55
RELAY_PIN3,-1
RELAY_PIN4,-1
RNGFND_ADDR,0
RNGFND_FUNCTION,0
RNGFND_GAIN,0.8
RNGFND_GNDCLEAR,10
RNGFND_MAX_CM,700
RNGFND_MIN_CM,20
RNGFND_OFFSET,0
RNGFND_PIN,-1
RNGFND_PWRRNG,0
RNGFND_RMETRIC,1
RNGFND_SCALING,3
RNGFND_SETTLE,0
RNGFND_STOP_PIN,-1
RNGFND_TYPE,0
RNGFND2_ADDR,0
RNGFND2_FUNCTION,0
RNGFND2_GNDCLEAR,10
RNGFND2_MAX_CM,700
RNGFND2_MIN_CM,20
RNGFND2_OFFSET,0
RNGFND2_PIN,-1
RNGFND2_RMETRIC,1
RNGFND2_SCALING,3
RNGFND2_SETTLE,0
RNGFND2_STOP_PIN,-1
RNGFND2_TYPE,0
RPM_MAX,100000
RPM_MIN,10
RPM_MIN_QUAL,0.5
RPM_SCALING,1
RPM_TYPE,0
RPM2_SCALING,1
RPM2_TYPE,0
RSSI_ANA_PIN,0
RSSI_CHAN_HIGH,2000
RSSI_CHAN_LOW,1000
RSSI_CHANNEL,0
RSSI_PIN_HIGH,5
RSSI_PIN_LOW,0
RSSI_TYPE,0
RTL_ALT,1500
RTL_ALT_FINAL,0
RTL_CLIMB_MIN,0
RTL_CONE_SLOPE,3
RTL_LOIT_TIME,5000
RTL_SPEED,0
SCHED_DEBUG,0
SCHED_LOOP_RATE,400
SERIAL0_BAUD,115
SERIAL0_PROTOCOL,1
SERIAL1_BAUD,57
SERIAL1_PROTOCOL,1
SERIAL2_BAUD,57
SERIAL2_PROTOCOL,1
SERIAL3_BAUD,38
SERIAL3_PROTOCOL,5
SERIAL4_BAUD,38
SERIAL4_PROTOCOL,5
SERIAL5_BAUD,57
SERIAL5_PROTOCOL,-1
SIMPLE,0
SPRAY_ENABLE,0
SR0_ADSB,5
SR0_EXT_STAT,0
SR0_EXTRA1,0
SR0_EXTRA2,0
SR0_EXTRA3,0
SR0_PARAMS,0
SR0_POSITION,0
SR0_RAW_CTRL,0
SR0_RAW_SENS,0
SR0_RC_CHAN,0
SR1_ADSB,5
SR1_EXT_STAT,2
SR1_EXTRA1,2
SR1_EXTRA2,2
SR1_EXTRA3,2
SR1_PARAMS,10
SR1_POSITION,2
SR1_RAW_CTRL,0
SR1_RAW_SENS,2
SR1_RC_CHAN,2
SR2_ADSB,5
SR2_EXT_STAT,10
SR2_EXTRA1,0
SR2_EXTRA2,10
SR2_EXTRA3,0
SR2_PARAMS,0
SR2_POSITION,0
SR2_RAW_CTRL,0
SR2_RAW_SENS,10
SR2_RC_CHAN,0
SR3_ADSB,5
SR3_EXT_STAT,0
SR3_EXTRA1,0
SR3_EXTRA2,0
SR3_EXTRA3,0
SR3_PARAMS,0
SR3_POSITION,0
SR3_RAW_CTRL,0
SR3_RAW_SENS,0
SR3_RC_CHAN,0
SUPER_SIMPLE,0
SYSID_ENFORCE,0
SYSID_MYGCS,255
SYSID_SW_MREV,120
SYSID_SW_TYPE,10
SYSID_THISMAV,1
TELEM_DELAY,0
TERRAIN_ENABLE,1
TERRAIN_FOLLOW,0
TERRAIN_SPACING,100
THR_DZ,100
THROW_MOT_START,0
THROW_NEXTMODE,18
THROW_TYPE,0
TUNE,0
TUNE_HIGH,1000
TUNE_LOW,0
VEL_XY_FILT_HZ,5
VEL_XY_I,0.5
VEL_XY_IMAX,1000
VEL_XY_P,1
VEL_Z_P,5
WP_NAVALT_MIN,0
WP_YAW_BEHAVIOR,2
WPNAV_ACCEL,100
WPNAV_ACCEL_Z,100
WPNAV_LOIT_JERK,1000
WPNAV_LOIT_MAXA,250
WPNAV_LOIT_MINA,25
WPNAV_LOIT_SPEED,500
WPNAV_RADIUS,200
WPNAV_RFND_USE,1
WPNAV_SPEED,500
WPNAV_SPEED_DN,150
WPNAV_SPEED_UP,250
