#include <LiquidCrystal.h>
#include <Servo.h>
//SETUP
int wartezeit = 300;
int v_toleranz = 3;
int h_toleranz = 2;
int schwellwert = 85;
int Vert_mitte = 75;
int Hori_mitte = 90;
int calibrate1 = 0;
int calibrate2 = 0;
Servo myservo1; // create servo object to control a servo
Servo myservo2; // create servo object to control a servo
int rssi1 = A0;
int rssi2 = A1;
#define SPKR 9
int rssiTrack = 0;
int rssiFix = 0;
int durchgang = 0;
int rssiTrackOld = 0;
int rssiDiv = 0;
int i=0;
int y=0;
char richtung;
char Vert_richtung;
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
void setup()
lcd.begin(16, 2);
myservo1.attach(10); // attaches the servo on pin 10 to the servo object
myservo1.write(Vert_mitte);
myservo2.attach(11); // attaches the servo on pin 11 to the servo object
myservo2.write(Hori_mitte);
y=Hori_mitte;
Serial.begin(9600);
lcd.setCursor(0, 0);
lcd.print("michael-heck.net");
lcd.setCursor(0, 1);
lcd.print("calibrating...");
for(i=0;i<10;i++)
calibrate1=calibrate1+analogRead(rssi1);
delay(25);
calibrate1=calibrate1/10;
for(i=0;i<10;i++)
calibrate2=calibrate2+analogRead(rssi2);
delay(25);
calibrate2=calibrate2/10;
pinMode(SPKR, OUTPUT); //set the speaker as output
digitalWrite(SPKR, HIGH);
delay(500);
digitalWrite(SPKR, LOW);
delay(2500);
void loop()
// Map values to defined range
rssiTrack = map(analogRead(rssi1), 0, calibrate1, 0, 100);
rssiTrack = 100 - rssiTrack;
//rssiTrack = analogRead(rssi1);
rssiFix = map(analogRead(rssi2), 0, calibrate2, 0, 100);
rssifix = 100 - rssifix
//rssiFix =analogRead(rssi2);
if (rssiTrack>100)
rssiTrack = 100;
if (rssiFix>100)
rssiFix = 100;
//Info to searial port
Serial.println(rssiTrack);
Serial.println(rssiFix);
Serial.println(" ");
//Display rssi values
lcd.clear();
lcd.print(rssiTrack);
lcd.print(rssiFix);
if(rssiTrack <= schwellwert)
trackHorizontal();
eject:
delay(wartezeit);
void trackHorizontal()
i=Hori_mitte;
do
rssiTrackOld = rssiTrack;
if (rssiTrack>100)
rssiTrack = 100;
if (rssiFix>100)
rssiFix = 100;
rssiDiv = (rssiTrack-rssiTrackOld);
if (rssiDiv <= 0)
rssiDiv = rssiDiv * -1;
if (((rssiTrack+rssiFix) / 2) <= 50)
else
if( rssiDiv <= h_toleranz )
if(rssiTrack <= 45)
if(i >= Hori_mitte)
i = i - 30;
richtung = 'L';
else
i = i + 30;
richtung = 'R';
else
lcd.clear();
lcd.setCursor(8, 0);
lcd.print(i);
lcd.print(rssiFix);
//lcd.setCursor(3, 1);
//lcd.print("Rssi gleich");
//lcd.setCursor(15, 1);
//lcd.print(rssiDiv);
trackVertikal();
else
if(rssiTrack>rssiTrackOld)
if (richtung == 'L')
i = i + 10;
richtung = 'L';
else
i = i - 10;
richtung = 'R';
else
if (richtung == 'R')
i = i + 10;
richtung = 'L';
else
i = i - 10;
richtung = 'R';
lcd.clear();
lcd.setCursor(4, 0);
//lcd.print(rssiTrackOld);
//lcd.print(i);
lcd.setCursor(12, 0);
// lcd.print(richtung);
lcd.print(rssiFix);
myservo2.write(i);
if (i <= 0 || i >= 180)
lcd.clear();
lcd.print("Reset");
i=Hori_mitte;
goto eject;
delay(wartezeit);
while (rssiTrack <= 98);
eject:
return;
void trackVertikal()
int loopi;
// lcd.clear();
// lcd.setCursor(0, 0);
// lcd.print("Beginne Track V");
// delay(1000);
loopi = 0;
do
if (rssiTrack>100)
rssiTrack = 100;
if (rssiFix>100)
rssiFix = 100;
if (rssiDiv <= 0)
if(rssiTrack <= 45)
y=Vert_mitte;
myservo1.write
return;
else
lcd.clear();
//lcd.print
lcd.print(rssiFix);
else
if (Vert_richtung == 'O')
y = y - 5;
Vert_richtung = 'O';
else
y = y + 5;
Vert_richtung = 'U';
else
if (Vert_richtung == 'U')
y = y - 5;
else
y = y + 5;
lcd.clear();
//lcd.print
lcd.setCursor(15, 0);
//lcd.print(Vert_richtung);
//lcd.print(rssiFix);
myservo1.write
if (y <= 10 || y >= 100)
lcd.clear();
lcd.print("Reset");
y=Vert_mitte;
goto eject;
delay(wartezeit / 3);
loopi++;
while (loopi <= 4);
eject:
return;
